Battery Importance
jc56berg
houston, TX
I have seen, read and checked a hand full of threads about the battery in our Rams. Most recent Thread: P219A code 5.7. The "change or check your battery" comes up a lot. A strong battery is important for todays vehicles and it doesn't fix all the problems but discussions seem to evolve around the battery frequently. Do our Ram batteries never sleep, go in sleep mode, throw codes etc...? My OEM went door nail dead 14 months ago. No surprise the summer heat here will kill one like in Canada cold. Had my mechanic replace it with other maintenance. Super Start brand battery.
Hagar1
Ontario Canada
2012 Ram 1500
WOW!! OEM battery? Eight years. Thats impressive.
I have an Ever Start that I purchased in May of 2019, it has a date sticker on it 3/18. I pulled it out of my truck last year to put in my van. It is still going. I've done a load test on it and while not perfect, it still passes.
I'm in Northern Ontario. Where the Black flies set up drilling rigs on any exposed skin!
Dean2
Near Edmonton
The 2020 Jeep my wife drives daily still has the OEM battery and it load tests at 96% after almost 7 years of service. My 2021 Pickup that doesn't get a lot of use, 25,000 miles in 6 years, tests at 98% but it has a minder on it when parked for more than a couple of weeks and it is in a heated garage.
Batteries last so well in our cooler climate that Costco still has a 60 month full replacement plus another 48 month prorated warranty, so total 98 months. Almost all my batteries that get replaced get Costco batteries.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I changed my OEM battery a few months ago on my 2015 just because of age !
It was still working fine !
So 10 year's old I am happy :)
Maybe Maine winters help LOL
turkeybird56
Central Texas
It's not the battery not going to sleep, it is all the computer modules that run for various amounts of time after you turn off your truck. There are a few modules THAT never go to sleep. Once your truck finally shuts down, you will have at least a .30 milli amp draw all the time. Further, modern vehicles, alternators are not designed to "charge" your battery fully, but to keep a "running" charge. And, if there is an issue where you have a module and a parasitic draw, that not help either.
When you buy a battery, you would do well once you got it home to put a charger on it and get it up to 100% SOC (status of charge), as batteries sitting on a shelf are almost never 100% ready. If you take a lot of short trips, especially a lot of stop and go in town, and not a long trip once in a while, that will gradually pull down a battery also, cause starting the truck is a monster voltage pull. That is why a lot of folks put their batteries on a maintainer/tender once in a while, especially if a truck sits a long time between starts. Soke people keep a charger mounted in their truck permanently and plug in frequently.
Finally, the heat in H Town not help either.
All above IMHO.
turkeybird56
Central Texas
I got 7 year out of my OE battery. Guess I'm just lucky.
I got almost 4.5 years outta my original OEM (actually 5.5 years calendar time, as truck was built in April 2018, and I bought in Aug 2018). Put in an AGM and got 4 months, battery bad. Put in another AGM, SO FAR OK.
wrigley
I have a 2023 that I purchased in May of 2023. I just replaced the OEM battery 2 weeks ago (6/14/26). Dead as a door nail!
MarshRam
2014 SLT 4x4, 2012 ST
In FL, all batteries in all vehicles have always dumped at slightly after 4 years. I always took all them in slightly before that 4 year warranty expired when they still worked, but were obviously not optimal and checked out in the tests. Free batteries for nearly two decades. Went in a few years back and noticed the warranty dropped from 4 years to 3 years. Now I have to pay for them :emotions122:
70runner
SOCAL
3.0L SST
I'm one of those folks. Keep the truck on a 2amp trickle charger when not driving for more than a couple days. Optimum battery state on these trucks is critical. If your vehicle has electronic modules with sleep apnea, parasitic draw will degrade the battery state and may cause electrical gremlins and/or prevent start.
Sure, a trickle charger treats the symptom, however, it may avoid multiple trips to the dealer where they may or may not be able to track down modules with sleeping disorders. Previous 21 Rebel had a variable parasitic draw, 50-200mA, that the dealer was unable to track down over 2 visits. Put it on a trickle charger, no more trips to dealer.
jasonw
South Dakota
3.0L Hurricane HO
Thats nice. The Costcos in the USA all only have a 36 month pro-rated warranty, no full replacement anymore. Hence why I stopped using them.
mb33458
V6 etorque
OK, so I have been following this thread for a while, but didn't want to post for fear of bad juju. Today I can post. I got 5 years and 3 months out of my OEM battery, in S Fla heat. Last couple of days I noticed the start/stop wasn't working, with no trouble indication on the dash. Tested the battery today with my load tester and it was at low reserve, on the verge of failing. I think I could have gotten a couple of weeks out of it by charging it, but it's too hot out to risk walking. Replaced my OEM with a Duralast AGM.
Grenadiers
Winnipeg, Mb
5.7L HEMI
My wife's Toyota 4Runner last year (2025) needed a new battery. That was her 2nd battery. The one she replaced was the original that came with her 4Runner when she purchased it ...in 2005!! 20 years!?!?! I told her that she MUST of replaced it years ago, but she was insistent and it was confirmed at the Dealership (by the date code) that it was the original battery! Even they were impressed!
On my 2019 1500, I replaced mine 2 years ago (original lasted about 6 years) with a AGM from Costco. Did so for many reasons, but mostly because of the warranty.
Oh, and we live in Winterpeg,MB...
Marshall
Sk, Canada
2014 sport
I just changed my original 2014 battery late last year, so 10 yrs and a bit.
years ago I had a large 27 series battery in a 1967 grain truck that was 25-30yrs old when I sold the truck.
As long as they are kept charge and don't freeze if dead, cold don't hurt battery's.
if they freeze, usally crack the case.
Mind you that was on old type cases that are brittle, some where 6 volt.
Hagar1
Ontario Canada
2012 Ram 1500
Freezing didn't seem to hurt my battery in the truck. It froze again last winter because the 6 feet of snow on the hood prevented me from putting a charger on it.
Once the weather warmed, the battery thawed, I put the charger on it and it Works ok. For how long? Time will tell.
