Any comments about the factory spray in bed liner?
I have the factory spray in liner, so far VERY pleased with it, extremly thick about 1/8th inch. plus if there are any problems it falls under Dodge to fix...
The factory bedliner is not 1/8" thick (125 mils), it's about 70 mils thick. The warranty is only 3 years/36K miles, the Dodge dealer can't fix it if you have a problem (he will have to send it to LINE-X or other), and the factory bedliner is aromatic (will fade).
LINE-X is 125 mils on the floor, has a limited lifetime warranty that's valid nationwide, and if you get LINE-X Premium or Platinum, it won't fade.
