Been having a hard time with my ram
mumbles84
5.9 magnum
The iac valve been acting up for about a year i have change it once no difference it runs and dosent die when i press on the gas is dosent close i get a whistle which drives me crazy every once in a while it runs fine thats when i love the truck im think tps or map sensor might be cuasing any one else have the cure for this
mumbles84
mumbles84
5.9 magnum
I found the terminals were spread on the tps and iac we are back to burnning tires hope this is the fix ill post back in acouple days
emjohn4
Make sure all your vacuum lines are good. That'll also cause idle problems, and "whistling" noises.
