sped68
So I’m sure I’ve read on here this kit will work for the regular cab 4x4 but I can’t seem to find that thread or discussion anymore. I’m assuming it works, I can’t see why it wouldn’t anyhow. I would like to hear from anyone that has installed this mainly to find out how much drop they got in the rear. I’m assuming it’s not the full 4” because the comparable Maxtrac 2/4 kit indicates it will give about 1.5” less drop in the rear when installed on the regular cab trucks. If this is the case with the Belltech kit is this going to cause an issue with the pan hard bar relocation bracket and it not aligning the rear end correctly? I’m guessing that bracket is designed for the rear to drop the full 4” like on the crew cabs.
