Best fuse to tap for keyed on acs. on a 2012 Ram 1500.
OnSale
5th Gen Crew
Philadelphia, Pa
I installed the modify street lights and need to tap the fuse box for the DRL feature. The instructions said to tap fuse F66 but that must be for the 13+ Rams because my 2012 doesn’t have a F66 fuse. No F labeled fuses at all, but a bunch of other letters.
Anyways, what letter+number fuse would I want to tap into for the drl harness?
If I need to post a picture of the fuse box cover with the fuses listed, I can, just let me know. Was hoping someone with a 09-12 ram knew off the top of their head which one is a keyed on fuse. Thanks.
CG2742
Mesa
Cigarette lighter. Or that spot for phone charging. Power seats
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
What? Those are not fuse numbers or fuse spots, I know where to hardwire it if I wanted too, I’m asking what specific fuse slot (letter and number) I should tap into, not what wires I should splice into.
CG2742
Mesa
I know. In the fuse box all these items are on fuses. They are low power that turn on with a key. That’s why I mentioned as they are key activated
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Ok, I’ll check the fuse list and see if any of those are listed. I was hoping for someone with a 2012 that could tell me “tap fuse J14” or “tap fuse B4” but I’ll look for the ones you listed and try them out. Thanks.
Jimmy07
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
SSGTD
