Best Solution to Shine Black Powder Coated Rims?
LSU04_08
Northwest Louisiana
Hemi 5.7 e-torque
What are the best products to use in order to shine or clean your black powder coated rims? They look nice when I wipe them down with a clean rag, but I'm wondering if there's something that actually shines them without damaging the texture or powder coating. I've tried Googling it (normally never fails me) but the only thing I found had "2500 Silverado" on it.
Bigs
Gatineau, QC
5.7L HEMI
You can use basically any wheel cleaner and then you can coat them with a wheel sealant (Poorboy's, Chemical Guys) or even just a QD spray.
Start on small areas first to test but it shouldn't be a problem.
I tried the P&S Brake Buster cleaner last weekend, I like it a lot!
Treburkulosis
Your High End Detailer
Haslet, TX
I am using Adams Graphene Detail spray or CG speed wipe on mine.
LSU04_08
LSU04_08
Northwest Louisiana
Hemi 5.7 e-torque
Thanks. I guess I worded my question wrong, I meant sealing/waxing them. After I washed my truck Saturday, I sprayed some Maguires Hot Shine on the tires, wiped them down and used the same rag to wipe the rims down.
Before:
After (That's not a crack house in the background, it's my shed I rigged into a deer stand):
A little bit of a difference. I didn't want to risk damaging the surface of the rims by having tire shine on them so I washed it again yesterday.
Bigs
Gatineau, QC
5.7L HEMI
Yep most wheel sealants should work on your wheels. You could probably try a Quick Detailer also (Like Turtle Wax Hybrid Solutions Detailer). Try on a small spot first and see how it goes.
You know what? My side steps are powder coated, I'll try my QD on them and let you know the result. I've also use my tire shine and that worked very well, not sure what the long term effects will be though of using tire shine on them.
carl0
Hemi 6.1
I use Adams Graphene Detail Spray. Just spray and wipe.
Rickl82
St Louis
I have been dealing with the same issue. All im going to say is yes be cautious, i wish i had been. I tried just about everything on the shelf, something created a white wash like staining on my wheels. Sorry to say i compounded the mistake by not catching which one exactly did it. But all the products I tried were for wheels and 1 of them is dangerous for these wheels
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
some have acids in them, so yes, be careful. Wash them with water and soap, and ceramic if you want them easier to clean.
BOWERSFJ
Uniontown OH
Turtle Wax Hybrid Ceramic Spray . . . $15 at Walmart . . . Works awesome with no fear of damage
