Best Tonneau Cover
daperp
N/A
N/A
Looking for input on the best Tonneau Cover on a 1500 crew cab 5'7" bed
Need it to secure as I do go into some crazy neighborhoods
Thanks in advance for the input
Boompa
I don't know about "best" but I'm VERY pleased with my BAK BakFlip G2. It's VERY secure and seems super solid. It was easy to install after watching a couple of YouTube videos before starting the job. Locks securely with the tailgate.
BlackWidow
2014 Ram
I'd say best is a matter of opinion.
Recently installed a BakFlip HD on my wife's Ram and was pretty impressed with the construction of it.
Like G2, when the tailgate is closed and locked the bed is as secure as it can be.
chootum
Advantage Hard Hat. Solid, simple, secure, american and 100% waterproof. Can't get any better than that.
RossM
The same as the other guys. I am using a BakFlip FiberMax.
Great seal and can hold up to 400 pounds on it.
Wandell
Cummins 6.7
I really like my Undercover. It's very light and secure and you have the option of a black textured or smooth painted to match finish.
Agron1979
Fort Worth, TX
I have the undercover lux se...a little expensive because I got it color matched, but worth every penny...lockable, strong, sleek, and water tight, nuff said.
THETANK
up jor *** mang
2015 R/T
I am thinking the one piece fibreglass (colour matching of coarse) tonneau has to be the most secure,
Kenny kustom
Manitoba, Canada
cummins
I had the ford branded undercover on my f150.
Colour matched.
Great cover aside from one thing. With the locks on the side, I found I could lift the middle of the cover up enough to open the tailgate.
I doubt, with the larger tailgate of a ram, that would be possible... But I went with the mopar tonneau this time.
It latches in the middle, to a footman loop on the tailgate.
Grad12
v6 3.6
Check out diamond back covers. You can haul on top, they are fully lockable and extremely versatile. If you want the best, it is definitely top 3 on the planet for tonneau's. No joke.
Stage4
8 Cyl
If security is your main concern, I'd recommend a RollNLock. It's the only retractable cover that locks on both sides of the bed AND it locks into the tailgate. However, their is a piece of hardware that must be installed on the tailgate that requires four screws to be drilled into the tailgate.
RAM_CRNA
2015 Ram 1500 Laramie Crew
5.7l Hemi V8 MDS 4x4
Anyone seen the YouTube on fold a cover elite G4 vs bak? I was a little disturbed when the guy was able to open the cover with a coat hanger.
tncruiser
kingston tn
5.7hemi
i don't have my ram yet ,but do have an opinion . on my last pick up a 07 lincoln mkt ihad a color math fibre glass cover looked great ,but i no longer had a PU it became a SUV when i find my ram i will install a roll up type.
brianj
will have my ram in the next 60 days
Klaus96
Illinois
2014 2500 CC Laramie 4x4
I went fold-a-cover G4 for 2 reasons:
1. My uncle has had one for 8 years and no issues.
2. You can open the panel behind the cab without opening the hole cover. Locks and opens from there and the back as well.
