bilstein 5100's for lifted truck
The Assassin
B-more careful, Murderland
So, I am going to be picking these up for my truck soon. Currently have a 3" body lift, and a 6" suspension lift (blocks in the rear). Does anyone know if with the new shocks I would need to modify anything?
bigtigga84
dela....where?
Did the suspension lift have rear shock relocators? Fronts shouldn't be an issue
RubberFrog
Probably 4" longer for the the rear. I assume in the front you had a 6" spacer on top of the strut, so you can use a stock replacement up there. Or an adjustable shock for even more lift.
The Assassin
The Assassin
Correct. So George, you think I can run the 5100's ok then with my current set up?
bigtigga84
dela....where?
After I asked I remembers you had the nitros on there. When I emailed them about getting the lift, I told them I had bilsteins and would be using them. They never said anything about them not working
RubberFrog
In the front, yes. I would do the 5100 adjustable so you have flexibility for the future.
In the rear, you can NOT run a stock length shock. Remember, you are 4" taller in the rear. That means a stock shock would already be extended an additional 4". Figure a stock shock has 10" of travel (if you're lucky), and that only leaves 5" up and 5" down. You would be using 4" of that travel leaving you with 1" left for extension. They would work great for bottoming out though....
The Assassin
The Assassin
Hmm..what should I do with the rear? The leaf and shackle set up like you have? Then, I would need a larger block and u bolt right?
RubberFrog
It would be great if someone had a stock shock and could measure it collapsed and extended for us. You could then look for a shock with a 4" longer length both extended and collapsed. Or even greater length if you plan on more lift.
So who has a stock 4wd shock?
RubberFrog
You already have a 4" block in the rear, correct?
A shackle and leaf combo can easily get you another 3-4".
So add the 4" for the block, and the 3-4" additional, and you will need to add 7-8" to the stock shock collpased/extended length to find an appropriate shock.
If you want to stay level, and you add 2" via an adjustable bilstein up front, then swap your 4" block for a 2" block and do the shackle/leaf combo. That leaves you looking for a shock with 6" over the stock collapsed/extended length
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
haha, stock on this site?
Dan you should go with something like this :)
The Assassin
The Assassin
Correct
Gotcha....hmmm well the blocks in the rear are stacked, so I guess I could just remove one of them?
I'd love to run a full Fox or King set up. They are expensive though.
RubberFrog
They are bolt on. You just need to find someone that knows the part number. lol
Try calling Trick Trucks Tell them you have a truck with 6" of rear lift (or whatever you're going with) and ask for the appropriate bilstein.
Marty424
