Bilstein 5100's with rear lift blocks
ctechnow
I have my front Bilsteins set to max height which has me pretty level (maybe a 1/4in higher in front) but I tow a boat and want a little more lift in the rear. Bilstein says 0-1 inch lift for these rear shocks. I'd really like to do 1.5 inches but I can only find 1 inch or 2 inch blocks. Does anyone know where to get a 1.5inch lift block for the rear? Would a 2 inch do any harm?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If you dont want to have to worry about the shocks could always just toss in a set of helper bags that you can air up while towing or have a loaded bed.
kyleb8077
Little Rock, AR
2020 Rebel
If you actually want to sit somewhat level or with a slight rake, I wouldn't go 2". Otherwise you will end up with something close to the rake of a factory truck, just higher. Daystar makes 1" and 1.5" rear spacers, TGC also make a couple different sizes. Im sure someone on here has some input on these or maybe a different option.
ctechnow
ctechnow
Appreciate the quick responses. I am open to the idea of airbags but I'd like to start with a spacer as a cheaper option and i only tow a few times a month 6mos out of the year. I was not able to find a 1.5" rear spacer by Daystar or TGC for a 1500 with 4x4?
smarsmar101
Waterford. CT
I have a 1inch spacer for sale right now...
And I agree, the bags would help alot... There is another member on here selling some of those too...
So really you could get spacers and bags at a discounted rate from the forum...
ctechnow
ctechnow
Per our PM your spacers are for 09-11 which wont fit my truck and those bags are sold too. I'm back to the drawing board but appreciate your efforts!
kyleb8077
Little Rock, AR
2020 Rebel
Daystar™ - Driven by Design
I found this on Daystar's website. Does not give a price so not sure on that. The bottom item, I think, is what you are looking for.
ctechnow
ctechnow
ctechnow
ctechnow
I assume these install between the upper rear shock mount on my frame and the upper part of shock but is there a DIY guide for the installation?
ChloeBrooks
