Bilstein 5100s
Machete
Figured I'd tackle this install with some decent weather finally showing up. Not off to the best start. I noticed I only have one spring clip. This is after I have the first side completely apart. I just have a few questions.
All my questions are regarding the installation of the Bilsteins into the spring..
1) I guess the spring has to be compressed more to fit the higher settings compared to the stock?
2) Is it vital that I keep that black plastic housing that goes inside the springs?! It won t stay in place and keeps sliding down. I assume it s just to keep debris out..
3) I read a member recommends the washer doesn't contact the nut and sits at the top of the piston?
4) Is anyone not using a torque wrench? Should the top nut be to a certain spec before releasing the spring compressors. .
Thanks
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
**** it, just pay someone. That's what I did. Wasn't an arm and a leg.
M
Machete
I normally would but I m trying to be cheaper ; )
smoothee
St. John's, NL
1) yes
2) wouldn't say it's necessarily "vital," but I would highly recommend it. Depending on where you live and type of conditions you drive in. How exactly is it sliding down? The top portion of the sleeve should seat snugly once assembled.
3) correct, the washer does NOT go directly under the nut. It goes underneath the strut mount.
4) I just gave the nut a quick shot with an impact. Very hard to get enough leverage for a torque wrench I found. It doesn't need much, so as long as the mount is seated snugly against the washer you'll be good to go.
JD0l4k48
Did you get a dealership to do it or someone you know?
M
Machete
Hey thanks. Yeah, I was installing the sleeve wrong haha.
M
Machete
Everything is tight except the upper ball joint nut. Keeps freely spinning. Almost done. A lot of breaks taking care of the daughter..
I'll definitely pick up a set of deep sockets for the other side and a torque wrench which I ve been needing for awhile. .
iam_canadian22
northern ontario
Use 2 wrenches for the balljoint, one on the nut and a 10mm i believe on the tip of the threaded shaft to hold it from turning
akra11
Kitchener, ON, Canada
2016 Laramie Limited Crew Cab, 8 speed
5.7 ltr Hemi - 8 Speed; T1000 Diabolo - Custom Hemi Tune
1) yes
I agree with smoothee.
the hardest part was to compress the springs. Had mine done in just over two hours total.
now looking for some HD rear coil springs.
Any one has an idea where the best place to get those?
SOKY_RAM
Bowling Green, KY
So say I have this friend that just put these on his truck and put the washer on the top side under the nut. Should he take all that crap apart again just to move that washer or just ride it out. Anyone else figure this out post install and just leave it?
akra11
you might run the risk that the rod comes thru the shock mount over time since the rod and the plate diameter are not too far off. I would change it to be save.
Csanders1992
I'd definitely fix that. It can wear it out over time and cause a clunking
M
Machete
Hmm. Everything seems good. But I gained no height. I only did the passenger side so far. It s identical to the drivers side. I 100% set it at 2.1. What s likey the issue here?!
Thanks
sriley531
Ohio
Man, you guys got me second guessing the crap outta myself on this one. Anybody got a pic or schematic that shows this??
(Sorry to the OP for sidetracking, this just seemed like a logical place to post this given the conversation)
AustinB
Banned
San Diego, Left Coast
The ****** part is that you can't see it without pulling the strut... So if a shop did it wrong, well.. Good luck.
IMO
sriley531
Ohio
IMO
No shop to blame, it was me. But I really can't remember where I put that washer!
akra11
So thought it was time for a change. After Bilstein 5100 front installed, I decided to ditch the 22"s and went with 285/65/20 on stock sport rims. Also added HD rear coil springs which gives her a bit of rake back.
Sent from my SM-G530W using Tapatalk
pepsiracer24
I like the look of leveled with stock rims. I bet they would look good powder coated in black too.
Nice truck! Exactly what I'm looking to do once I buy on granite sport
akra11
Thanks, ya, thinking about powder coating them. Have to find a good place who can do it around here.
joshhhh
