TOM153
So I have a 2017 Ram 1500 and I just installed a superlift 4” lift kit. I had bilstein 6112’s prior to installing this kit that were at 2.8. With this lift kit I set the bilsteins to 0.8”. Now at full droop and turning maybe half towards lock left or right the new superlift knuckle hits right into the spring. It actually pushes the spring in. I also have JBA upper arms if that helps but I’m hoping it’s an alignment issue as my alignment is very screwed up at the moment. I know people that have used this set up and claimed no problems but has anyone run into this issue on here? Thanks
