Blend door clicking even though key is off
Timbo99
Burnsville, NC
New to forum, I own a 2007 RAM 2500, one of the blend doors wont stop clicking even when key is off. How do I stop it? Worried it will run battery down. Thank you
GRKN
It’s normal for the actuators to move after the vehicle is off to shut down the system. Are they continually moving afterwards and not stopping? How long are they moving?
T
Timbo99
Burnsville, NC
New to forum, I own a 2007 RAM 2500, one of the blend doors wont stop clicking even when key is off. How do I get it to stop, it's high in the dash.. Thank you
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Unplug it. Check the connections in the plug. If all OK (power/grounds). Probably needs actuator.
pacofortacos
Chances are the actuator is broken and so it doesn't sense the park position - and keeps trying to park but is unable to.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
take out your glove compartment(s)
then using a flash light shine the light over towards the left
You will see & you could touch the actuator & feel it move
you can change the setting on the control panel & watch it do its thing.
There are 2 screws that hold the actuator in place
If you take it out, try removing it while the actuator white lever is in the down position. That makes it easier to put it back in place.
If you look up at the underside of the dash, you can see another actuator, you could move that actuator to the Blend door position & see if that changes what the original actuator was doing.
the OEM Actuators are self calibrating & heavy duty, they are also priced fairly, maybe $40
The actuators can be disassembled & if it is a white plastic gear that is broken, you can rotate the gear 180 degrees & usually they will function correctly again.
Hope this helps, by the way, there are several youtube videos about the HVAC actuators for 3rd Gen Rams
T
Timbo99
Burnsville, NC
Thank you for the suggestions, I pulled the vac fuse and that didn't stop it either not sure where it's getting its power, would anyone know?
Thank you again
ChloeBrooks
