Bluetooth and parksense LOUD
Kbaungartner
Ohio
I installed a dsp and amp in my truck and now the Bluetooth and parksense are way to loud I had to turn gain down on my,amp which is bad because I can't adjust gain to proper setting. Is there a way around the overbearing Bluetooth and parksense?anyone else have this problem?
14 Lonestar
You should be able to adjust the park sense volume level in the settings on the radio, I assume you have the 8.4?
K
Kbaungartner
Ohio
Yea I do have that and it is set on low and it's still really loud .if I talk to someone through Bluetooth I have to turn my volume to 1 and it's still loud
adurm
FL
2015 RCSB
Sounds like some setting in your dsp. Which dsp are you using?
adurm
FL
2015 RCSB
Hook up the pc to it and turn down the phone sensitivity. I never hooked up a phone connection on my other car. Just front inputs. Bt calls come through fine.
