Robertgjr
Hello everyone, new to this forum and have a question regarding brake fade on a 1994 Dodge Ram 3500 Dually with the 5.9 Cummins engine. Ok, replaced both front calipers and both rubber brake hoses and master cylinder(twice). Bled the complete system, rr, lr, rf and lf and brakes still fade. When you pump up the pedal it will hold then start to fade to the floor. Now when we bleed the system again(about 3-4 times now) after doing the back the pedal feels good but has fade. When we bleed the front the pedal goes down to the floor. We ended up taking calipers back and getting new ones (again) but still the same issue. We were thinking about replacing the proportioning valve but we couldn’t find one, even tried the Dodge dealer. Have any of you had this issue before, if so what was the solution ? Thanks in advance for any and all comments, suggestions and feedback.
