Brake light issues
Tank69
V-6
I'm not sure if I'm in the right spot here but I'm gonna throw it out there , I have a 1989 Ram 1500 , was told yesterday I have no brake lights , checked fuses an bulbs all good , checked the brake light switch it fell apart in my hand . ...... I replaced the switch , now I have the brake light on the back of the cab ( which I've never had in the 3 years I've owned the truck ) but no brake lights in the tail end ......all other lights works ...checked wiring in back end it all looks ok .
sbarron
Wasilla, Alaska
always go back to the last thing you did.
check that furthest place upstream from the lights where the two systems, (right and left) are common... My guess is a bad plug, or loose wires in the plug at the at the brake light switch.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
............checked wiring in back end it all looks ok .
What does "checked" mean here? If all you did was a visual and not check power/grounds with a multi-meter, you have not eliminated the wiring as cause.
kennewbike
hemi
MY guess would be bad harness plug. I'd check it
joshhhh
