Brake lines tight
Matthew Smith
Georgia
I just put a 3in level on I haven’t put the wheels on yet. The lines seem really tight at full lock and passenger is worse. Do I need extended lines or what. The suspension is at full droop
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
yep need longer ones I would not drive it till you get the correct length you can get stainless steel ones on line. did your kit come with different brackets to move the lines? call the company you got from and find out
Matthew Smith
Matthew Smith
Georgia
do you think it’d be ok to take it easy and drive it till they get here cause it’s a my only daily
FF1899
Syracuse NY
I had 3 inch spacers then a 4 inch never touched the lines till now at 6 inches. Never a single problem
