brake problum
tomwandah
I have a 2006 2500 4x4 it started jerking to the left when the brakes was applied so I replaced both front calipers I still have the pull to the left and no brake pedal so I replaced the master cylinder and vacuum buster pressure bleed all brakes still no pedal gravity bleed all brakes still no pedal and the abs lite and brake lite stay on please help.
crazykid1994
Idk if the 3rd gens had it but I had a vw and I had to have a scanner so I could bleed the abs module electronically or the peddle felt squishy. After bleeding the abs module everything worked properly. It's a 2 person job.
