Brakes.....fyi
dodger2107
Orlando
I have a 2011 Express reg cab with 9200 miles on it,the other day I noticed a "squishy" noise when I stepped on the brake pedal,well today I took it to the dealer turns out it's also losing pressure/as a result they are replacing brake booster and master cylinder.Service guy said this has been an issue,time to check your brakes......
audio1der
Airdrie, Alberta
Oh, man. I was hoping the brakes on the truck would be better than those on the Caravan...:flame:
quietpeen
2021 TRX
Hellcat
So they just made a squishing sound? They didn't feel any different?
gmzvip23
2k12
Thanks for the info ill have to watch slammed on them the other day to avoid a texting sixteen year old. Ill def swap out the pads tired of the dust behind the wheels at 5600 miles.
Coppertone
South Jersy
Wow I am at 51,000 on OEM brakes and still stopping in a dime. Not that I am complaining....
dodger2107
dodger2107
Orlando
brakes
ok sorry it took so long to get back on here;yes they did kind of go down after you stepped on them they would kind of go down a little further,picked it up late yesterday they replaced brake booster and master cylinder(feels great now and no more "squishy noise)
audio1der
Airdrie, Alberta
Glad they fixed you up. Mine are still oem brakes and i dont have any.problems stopping my 37's. When i do changem im going to drilled/slotted rotors.
I assume you're familiar with the problems associated with drilled rotors?
Not that you'd be tracking your truck, but heat + drilled rotors= cracks. Slotted are great with the same benefits + added strength and more mass from NOT being drilled all the way through.
My $.02, each to their own :)
jhicks1983
