Brand new Ram looking for lift kits
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
With the 6" lift what is your over all heigth? I know it depends on tires size,
Thanks
6" lift only will add 5.5" up front and 4.5" in the rear.
throw on Bilsteins, and youll go up higher. add a body lift and well...up you go.
Swap in tires and up you go :********:
limited
2012 Black Limited 1500
When the kit said not for awd, On the limited I can switchs it to awd, or lock in 4 wd,
Will the kit work or do i need to somthing differnat?
Front: Front & rear cross-members, driver & passenger side differential brackets, driver & passenger lifted knuckles, driveshaft spacer, sway-bar links, skid plate and strut spacers.
Rear: Lifted coil springs, fixed upper control arms, sway-bar links, brake line brackets, track rod bracket, and bump-stop brackets.
Shocks: (2) Rear Performance 2.2 series shocks.
Notes:
• Kit is not recommended for AWD models.
• TRX models will achieve aproximately 1" of additional
lift. This lift is not recommended for use on the TRX models due to possible CV shaft vibration caused by the additional lift.
Consider our 4" lift system for about 5" of lift or replace the TRX struts with standard struts for use with this system.
thanks
fastNugly
Toronto, ON
Notes:
thanks
hope someone can chime in on this....as this is beyond my knowledge
ATOM
it will work on AWD but you might feel vibrations if your angles are above stock
limited
Went out and looked at the dial, it has 2/wd, 4/wd auto; and 4/wd lock,,,
I believe the salemen told me it's awd When you are in 4/Wd Auto,
dterrel
