Break in period??
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok guys, I am goin to have my new alpine type R 12's installed today in my new fox box.
My question is, do these speakers need a break in period? I've never done a break in period on any speakers before. But I don't want to screw these up. (too expensive to have to replace)
Droid Incredible 2 on the move!!!
HemiBabe
DFW
Not sure but I bet someone will know
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Never thought of having to break in subs, bump for the audio guys for a good question.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I can't imagine a speaker having a break in. Don't know how you'd do that.
EJM05
Somers, CT
440 Big Block
Put the Bass up as loud as it can go.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Well I guess ill just play them to the max then lol thanks guys!!!
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
yes and no. The break in period on subs is to let the glues settle in a heat/cool cycle. So expect some odd smells while you listen to them. I say listen to them under moderate levels for a day or two, then rock on. Gain settings of course should be set with an O-scope , but that pertains to any amplifier setting, not just new.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Well this sounds more logical!!! ;) thanks
Graygoose
Oklahoma
Convert, for now.
small
Yup, some also need to break in to loosen the suspension up for optimal SQ, mainly when sealed enclosure is used.
TheMaddog
DFW
subs, yes there is a break in period, but it doesn't take long, my kicker cvt 10s took a little under a day, but i wasn't driving that much, but put on the bass med/hi and let that go for a little bit.
speakers, yeas, but not nearly as long. i have sony xplod speaskers and as you listen to music, it gradually gets louder. doesn't sound like it, but i promise it does.
you should be done breaking everything in about a hour - 2 hours tops.
best of luck
Graygoose
Oklahoma
Convert, for now.
small
True, the CVT is for the glue/suspension like mentioned, Other than that, agree, couple hours, let em play.
TheMaddog
DFW
Play anything Kanye, he has sooo much bass
jhemi
wisconsin
the spider in all subs when new are stiff which makes the sub need more power to move the sub once broken in and amp is set right the sub will hit harder using less power than a new one if to much power when new voice coil heats up because of working to hard which in return burns out the voice coil, dont run at max until sub completly broke in, time is different on all subs, high end copitition subs can take days of continious play to properly brake in, the type r alpine 2-5 hours should be good, run for 20min let cool off run for 30 let cool off and so on, most people dont break in new subs and dont have a problem i love serious bass and push my equipment to the max so i always break mine in
Graygoose
Oklahoma
Convert, for now.
small
Amps aren't needed for break in, just subwoofers. No need on mids and coax either.
quietpeen
2021 TRX
Hellcat
i miss having a sub
Graygoose
Oklahoma
Convert, for now.
small
i miss having a sub
me too, my Yukon was out-fitted...as soon as I get truck mods done, system is going in. One would think that would be my fiurst mod :(
:naughty:
As long as it's done by spring.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I can say for our trucks this fox acoustics dual 12" vented box they have is THE BEST!!!!! Just got mine in with the type r's and its hella loud!!!!
