mayhem100
2016 crew cab Laramie Hemi. 152k-ish miles.
Had a heat shield rattle since I bought the truck this past summer. Very clearly a heat shield rattle, no ticking or anything else I would call an exhaust leak, but to be fair I'm new to Ram so I'm here to ask questions, not to make assumptions. Noise is present on cold start only, goes away after about 1-2 minutes.
Got some photos the other day, the passenger manifold heat shield is clearly partially rotted away and at least one bolt is out of its threaded hole, unclear if the bolt is broken, but I presume it probably is. Attached a couple photos below, my question is, is this a simple heat shield remove and replace or is the heat shield held on by the actual manifold bolts and this is probably just my first broken manifold stud? If so, is this something I should just deal with replacing the manifold and heat shield in the spring before the other studs break? Driver's side isn't making any racket but I have not done an inspection of that side yet.
Overall the truck was well cared for my the prior owner, very little corrosion, but if course manifold bolts will break when you try to take them out. I'm a diy'er, but have never had to deal with an exhaust manifold before, more or less most everything is doable, but how difficult is this job at home in the garage? I have a good place to work, but no lift beyond a jack and stands, so this would be done on my back and I assume through the front wheel well.
Thanks!
Thanks!
