Break line concerns when lowering 2/4 drop
Darth Vader
Woodstock
Hey everybody. I’m looking into lowering my truck with beltech 2/4 drop. I’m running 22 in x10 wheels with 305/45 R22 tires. Has anyone heard of any brake line issues using this set up. Thanks
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
No, I've had my truck lowered for several years. No brake line concerns at all. No rubbing, no issues, none
Lifted, depending on height of lift, different story.
A 22" wheel won't have any issues,it's more a 17" wheel problem,and then you can carefully tweak the rear brake lines to clear the rim.I had to tweak mine a wee bit for the 17" drag radials.They would of probably cleared with-out tweaking, but just to have a little bit more of a safety factor i bent them a bit.On the factory 20" they had lots of clearance.Hard to see,but they were tweaked in this pic.
