Bump stops with 4/6 drop
ready961
Ma
I have running without bump stops on my 4/6 drop for a year now. Need to add some so tires stop hitting the fenders in the rear and cushion the front a bit. What are you all running?
abouttobeglue
How do you install these in the rear? Cut the cups out a while back due to bottoming out
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I put a nutsert in the pre existing hole in the center where the cups were and screwed them in without the nut. You can find something to hold the nut and try to stick it through the frame but it is just too hard. A nutsert and lock tight. Mine have not moved. If I lose one, I'll replace.
