Sumosprings rear helpers Ssr-307-47
Paulswagelock
Pennsylvania
Hurricane SO
New to this forum, wanted to add content for allowing me to join.
I have had seven Rams over the past 12 years. I took a break in 2024 and tried a Tundra (save that story for another day). Came back to a 2026 Laramie crew cab with the Hurricane SO.
I tow a 29’ boat, about 8000 pounds, 800+ tongue weight. I had air suspension on my past Ram but decided not to check that box this time. I knew it would squat without some help. Used the Sumo’s on previous Rams so went back to them. Great addition to help with squat and ride comfort. Truck is unaffected when unloaded as there is a gap in the Sumosprings to the axle. On a hard bump it engages but not jarring, just a bit firm. Loaded with the boat, truck stays level, rides nicely, great low cost solution. If you tow and need some help, but want to avoid airbags, this is a good solution.
jason1
US
Those look nice. I wanted something a bit stiffer and went with Timbrens SES and couldn't be happier. But the sumo springs do have different levels of stiffness you can get which is nice. Airbags definitely provide the most flexibility and functions but I also didn't want to deal with them.
