Bumper chop
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Here you go! could you do both bumpers? and make them black please? thanks!
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Sorry bud havent got to this yet, I should be able to do it on Sunday
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
No problem I havn't really been here lately either. Been muddin and stayin at a friends house cause I threw an idler bearing in his driveway with no way to get home.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
I was thinking, If I where to go with the pipe bumper, where would I go about hanging D-rings from? I'd think the pipe would split if it had to take any real shock...that would not be fun in the mud...
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Sorry I forgot to post here. I tried getting the bumpers on there, but it looked hideous and wasn't worth posting at all.
Why hang d-rings if you could just use the bumper itself?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Maybe some thick wall roll cage tubing with a top peice longer with corners and the bottom shorter with no sides. To get good tubing you will spend some $$$$$ though.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Actualy, thats the reason I need a new bumper...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I think Lukes hinting at if your using a good bar you could just run the strap or shackle around the bar, then no need for d rings.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
Bar? I would almost like a pre-runner set-up tho to to reduce the shock on the frame when I find a ledge under water, but would that be street legal?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Lets start brain storming here. Your looking for a pre runner bumper with the abiltity to be attached to. The attachments will be for pulling either your truck out or someone elses correct?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Like this?
or this?
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
kind of a combination of both, the topone with less bars and slightly thicker bars with the bar of the second one to protect the grill .
(the top one with out the winch support and with the bar of the second one on top.)
rambob
LA/MS
318 5.2l
if you are looking for protection and a tow point that you can get built for cheap, you would be better off with 2x4 thick steel bar, like 52" and then add the tubes for grill protection. similar to what most jeeps use.
the tube bumper will bend and not do its job when you need it most.
Luke(MI)
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
jackpot, it was a tube bumper or one like the one above. what could I expect something like tht to cost? would like the bar almost as wide as the truck minus about 4" on either side if possible.
rambob
LA/MS
318 5.2l
a few guys near me would charge $150 to 2500 to build this one
joshhhh
