Cab lights
chris76522
I just bought a 2008 Ram 1500 and the cab lights that are on it dont work. any suggestions to get them working?
sbarron
Wasilla, Alaska
start at the fuse
then check the bulbs
THen check the wiring between the two
C
chris76522
Thank you where would the wiring be located?
sbarron
Wasilla, Alaska
between the fuse (or power source and the lights. Likely run up the A-pillar and between the headliner and cab roof. Pull the A-pillar cover off and if you see the wires, it may actually give you a good place to start tracing from.
C
chris76522
i didnt pull the a pillar off but i think i found it in the engine bay also under the dash there is a black wire that was cut put it back together and nothing so i have no idea what it goes to. took one of the lights off and one wire was cut, if that wire was cut would it cause the rest to not work? or is it not that kind of circuit?
thz71
No its not a series circuit
05daytona
I'm pretty they're wired in parallel, but you're right, if one goes out, they all go out when wired in series.
2008
If you look on the right side of the truck, there is a wiring harness already there for cab lights under pillar, start there if you want
Saleen5150
