Can anyone help with fuel pump?
Ram06_1500
New jersey
2006 ram 1500 5.7 hemi with pro charger etc. stock fuel pump went out. Was going to go with a Delphi unit then I read reviews about gauge not working. Then looked at OEM and couple of them are discontinued. For whatever reason there’s 4 different ones that have different part numbers and prices. Obviously can be for 26 or 34 gallon. I need for 26g. Tried calling 2 mopar parts only to get no response. Called dealer and gave me part # 52113603AD which states it’s discontinued. Can someone please help refer to the correct part or link?
LoneWolf3574
Give Mopar Parts Giant a try, they let you search by VIN and at the very least, you will get a part number to search for if you don't have the Parts Manual. I use them for OEM parts most of the time and it appears that they do have a fuel pump for the 2006 5.7L with 26gal tank. You could also go with RockAuto, which, in my opinion, would get you by in this case :/.
Part # 5104694AB replaced by RL104694AC ; Search terms - Mopar RL104694AC Fuel Pump Module/Level Unit
Steve58
