Can anyone tell me the purpose of this ?
DRkNESS
South Jersey
These are located underneath the drivers side of my side steps. They have markings but for what I do not know.
DRkNESS
DRkNESS
South Jersey
Here's a photo of it from the side.
It is probably some form of harmonic damper
Sent from my XT1080 using Tapatalk
2011 Ram 1500
Yeah^^ you can find them all around the truck. It's probably for small vibration
Sent from the fetal position using Tapatalk
DRkNESS
DRkNESS
South Jersey
Thank you as I wanted to make sure it doesn't need to be addressed rust proofing wise.
DRkNESS
DRkNESS
South Jersey
Them as in exactly how many are located underneath our trucks ? :(
catch 22
right here
none
That one is clocked to 422AA Yellow, you need to make sure all the rest of them are clocked the same or you may end up with a vibration.
DRkNESS
DRkNESS
South Jersey
^^^. Ok you're going to need to help me here lol, Ospho ?
scott68fl
3.6L V6 Pentastar
Yep vibration dampening weights to keep the cab more comfortable
Sent from my VIVO XL using Tapatalk
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
^^^^ Agree, Dampeners to help reduce any vibrations resonating through the frame.
Wish I had a nickle for every time this has been asked, I would have a nice chunk of change.
Yes, my 2009 has them also.
Ronan
I took them things off a long time ago
Did you notice any new vibrations after you deleted them??? Just curious... Always trying to shed some lbs.
Rzrman328
The treeline
I'm sure they're on there for a good reason.
I don't think they'd be installed for ***** n gigs.
crazy_luck
Minnesota
Yep. If they cost money, they are there for a reason - back when the LX cars came out, they removed the hood struts and replaced them with a prop rod because it was $6 per car cheaper. Anything to save a dollar in the corporate budget.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
A month after I got my truck mine were rusting like my drive shaft. I taped under carriage off and sanded down all rust spots and sprayed with a rust preventive and then sprayed black. I removed the weights and did the same and then reinstalled. 3 years later of New England driving with salt and look better than new! I also have my truck undercarriage sprayed with corrosion 3000. :happy107:
ChloeBrooks
