Can I take this off and drill through it?
Jack Archer
San Antonio, Texas
5.7 V8 Hemi
Or is this one up top needed for something? Its metal or a hard plastic, and on the inside is a small hole covered in a soft foam. I dont see anything going to or from it on the inside or outside. Im wondering because Im going to be putting some lights in and I wanted to run the switch into the cab and mount it somewhere in there. Or would there be a better area to run a wire inside the cab?
jeepguy_1980
5.7L
It's just a blank off, where the clutch would go.
No harm in drilling it.
Sent from my HTC6525LVW using Tapatalk
quietpeen
2021 TRX
Hellcat
what he said. This is the location where most guys running a power wire for amps goes through.
myoung84
Tulsa, OK
2012 Power Wagon
That's where I've always drilled to run my wires. You can take of off with a couple nuts on the inside of the cab to make drilling easier.
Sent from my Samsung Galaxy Note 3.
Jack Archer
Jack Archer
San Antonio, Texas
5.7 V8 Hemi
Thats good. Just wanted to double check before I did anything. My luck I would drill though it and thats the one part thats holding the entire truck together. I may have found a way to run the wires without having to drill anyting though. Bu this way would be a bit cleaner looking. And I can take this off you said? Whats the tool I would need to take it off? I looked on the outside and couldnt tell what it was.
012RAMbo
West Monroe, La
In your picture, you can see right above the red "548" numbers, there is a bolt and nut, and there is another to the left of the foam piece showing through. Use a socket, cant remember what size it is, to take those two nuts off.
myoung84
Tulsa, OK
2012 Power Wagon
I'm pretty sure they are 15mm nuts.
Jack Archer
Jack Archer
San Antonio, Texas
5.7 V8 Hemi
Very good. Thanks! Ill work on it this week. See if I can get my brother in law to help with the wiring.
