Tacopimp
I have a 2025 Bighorn that came with the factory bed lights. They barely light up the truck bed, so I bought some LED lights from Amazon. I would like to tap into the OEM bed lights, is that possible? Thank you
Well, I don't know if they have a harness with more than a 1 hot and 1 ground wire.why not?
if you want to do a simple install, remove a factory light and tap into the wires that feed them.Well, I don't know if they have a harness with more than a 1 hot and 1 ground wire.
I had the dealer install the Ram LED bed lights in my truck. They light it up pretty good. Wonder if you could just switch?
what LED lights did you get from amazon? usually, LED use two wires..red is + and black is - you can attach the black to any ground and the red to the + (hot) wire at thee lights
5th Gen Ram 1500 bed light video
being as you already have the OEM harness
You should be able to figure out just where to tap into it
5th Gen Ram Bed Cargo Light Installation
In this video I go over the installation of Mopar's bed cargo lights for the 5th gen Ram. These are available as an option on the Rams when purchased or, as ...www.youtube.com
Yes. The factory lights don't have enough voltage to power anything else, so tapping into those cause a short. Only way to directly tap into them would be to also use a relay. Seems like its easier to just tap into a constant 12v wire, and use a magnetic switch on the bed so they come on when the bed opens and breaks the magnetic connection.You need to measure voltage at the lights. I suspect it isn't as simple as Gnd and tap the "+". They may be wired in series or switching the gnd vs + or somehow going they the damned radio lol
Must be wired very differently in 2016. The voltage on the 2025 bed lights is not enough to power more than the Mopar Bed Lights. I am going to tapp into a regular 12v wire to get them power and use a magnetic switch.On my 2016 2500 I created my own plug-in harness that tee's out the connector that goes to the factory bed lights in rear corners to add an additional plug to add my own string of LED lights. Plenty to choose from on Amazon. Mine were squared shaped at each light so I 3D printed a mount puck (not an official name) that gives a slight angle for each light to point more towards inside of bed...not that you would need on all options available out there, but worked for me. Two wires to the LEDs, pos and neg. They come on when OEM ones do, and go off at same time as well. Thought of hard wiring to constant power with its own switch/relay, but tbh for my use that was an over engineering path. I mainly created a T harness to split out power so that when I replace later...as nothing lasts forever..... it would be easier and don't have to worry about the connectors since they are in the back corner bottoms of the truck where "stuff" usually goes when driving in rain/wet. Your truck, your choice as usual.
MD Sledhead - Roughly what did the dealer charge to add the bed lights in?I had the dealer install the Ram LED bed lights in my truck. They light it up pretty good. Wonder if you could just switch?
Sorry for the delay... less than 2 hours. maybe 1.5? I think they bill $90/hrMD Sledhead - Roughly what did the dealer charge to add the bed lights in?
Any update on this? i was going to do the same tie in leds by splicingI’m pretty sure the bed lights are CANBUS.
