Can i use my amps crossover to run my mids?
troutspinner
Gilbertsville, Pa
2026 Rebel G/T
Hurricane
It does not appear so as you can only pass one way, either above or below. With a mid, you would want to control the frequencies at both ends. You could always buy a cheap crossover. I believe you could also add a capacitor but you would have to research that further to match the power and frequency needs.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Im hoping I can add a set of bass blockers, and use the amps crossover to run the midranges until I can afford a DSP. I just ordered $720. Katzkin leather seat covers. Budget is currently tight.
FS_Vaprco
If the amp has a bandpass feature you can set the range you want or use a passive crossover for just the mid range your wanting, ebay, DIYMA or similar forum might find crossover for cheap that'll work
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Thanks, I was able to set my amps crossover at 150 hz and the infinity midranges are working very well.
adrianp89
Tampa Bay, FL
You should really find a used MS8 and install it. They go for about $300.
