Can my 2010 nav system be upgraded to play music via phone not just calls
Blanco716
Ny
Can my 2010 nav system be upgraded to play music via Bluetooth not just calls ?
audiophile
5.7L
Does your radio have an aux option?
jawzs2
Air Force
South Jersey
Depends on what nav system you have. In the lower right corner is a three letter code, either RHB (430N) or RER(730N). The RHB can be, you need to replace the uconnect module on the right side of the dash, behind the glove box with one out of a 2011 or 2012. If it's an RER, the only way is either to replace the radio with an RHR, (still known as 730N), again out of a 2011 or 2012, or go aftermarket.
metalchewy
Las Vegas
2010 TRX4
4.7L
If you replace RER with an RHR you also have to get the harness that ties GPS with Nav into one FAKRA curry connector. Or replace the roof Antenna with a dual.
Jus10case
