Can phone navigation display on non-nav radio screen?
Docwagon1776
Midwest
2022 1500 rental. No manual to consult. Have phone connected for music and calls. Won't display Google maps. I assume base radio. Tried bluetooth and wired. Any ideas?
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Unless it has Android Auto or Apple car play I don't think you can.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
Is it the 8.4? If so it has AA and ACP. 4th gen is wired, 5th gen is wired or wireless.
Different Drummer
North East
Pentastar V6
Fourth Gen. is wired? I can view my phone map/routing on my 8.4 non Nav activated screen? I did not think this was possible. Please tell me more.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
On my last truck (2019 Classic), the one I just traded in a couple of weeks ago AA was only wired. It was an older version, Uconnect 4c. The new version Uconnect 5 on my '22 5th gen supports wireless. Maybe the 4th gens are now coming with the newer Uconnect?
MADDOG
Living in a Firepit
6.4L HEMI
Unless the head unit has Android Auto or Apple CarPlay you won't be able to display Google maps.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If it is an 8.4 or larger screen if you plug your phone into one of the USB ports it should add an Android Auto or Apple Carplay icon to the screen from which you can open a NAV app installed on your phone.
*2018+ 4th Gen 8.4 non NAV radios have Android Auto and Apple Carplay but can only be used natively with a USB connection to your phone.
gofishn
Iowa
hemi 5.7L, 345 cu in
What he said.
Connect phoen to USB Port, turn on data and G icon will show up. click that adn ya got maps
Different Drummer
North East
Pentastar V6
I don't know guys. I will give it a try but I think that in my 2017 Laramie I cannot get the navigation from my phone to show on my 8.4 display. My year does not have ACP or AA. Therefore the only possible way would be a hard connection through a USB port. I believe that my in dash USB charges only. I can play music from a USB memory stick through the USB port inside the console. If I can plug my phone into the console USB port and display phone navigation on the dash display I would be elated. However, I don't think it is going to happen. BUT, I certainly will try.
Athlium
Tacoma, WA
3.0L EcoDiesel
CP and AA is not available on 2017. You can swap to an 2018 or newer radio to get them.
turkeybird56
Central Texas
Correct, 17 no dice, U would have to upgrade to a newer radio
turkeybird56
Central Texas
What he said.
YES.
OP, what post #8/9 said. also, if U are using an I Phone, U have to have SIRI working to get maps to work once you plug USB cord into USB outlet, The 2 under the dash/console, NOT in the center console. (What U have to have on for Android, dunno, got an I phone, LMAO).
tron67j
Maryland
If I find out that way works Im going to kick something…I dont think Ive tried that console USB…
Your profile says you have a 2017. Unless you upgraded to a 2018 or newer 8.4, your radio does not support Android Auto or Apple Carplay. You need one of these to transfer your phone's map to the radio screen , which then works through the radio touchscreen.
ThunderMug95
North Prince George, VA
Yep! Turkeybird and I mustve posted near the sane time and I hadn't refreshed. Was so disappointed I couldn't bring myself to acknowledge my 2017 shame lol.
Docwagon1776
Docwagon1776
Midwest
Update: works fine, just have to use the USB inside the center console lid. The one on the dash is charge only, apparently.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I have 2 USB inside the center console and both are media usbs..I have a 3rd usb option on my radio but I can't find that USB anywhere in the truck lol ...
David Oakes
Courtenay, BC
6.7 Cummins I-6 HO
I think that you're going to find it on the back of the centre console, rear passenger access.
My grandson used to drive me nuts by plugging his phone in there and it would start android auto on me...
Arturo Rojas
