Can the 3.73 do it
Saved by Grace
North Carolina
Need to pull fifth wheel with a 13000 lb dry weight. Looking to buy 2018 Ram 2500 6.4l. Having a hard time finding one with 4.10 rear axle. Whould I be risking breaking my truck if I bought a 3.73. Most diesel options are not in my budget. To clarify, I am only moving the 5th wheel once, not multiple times
dhay13
without knowing the max tow rating for that truck I'm gonna say you won't be happy with it unless you are on all flat ground. Your wet weight will likely be closer to 14,000. Not sure I'd want to do that even with my 4.10's
NH RAM
New Hampshire
2019 Tradesman 2500 Snow Chief
I'd pass, the 2018 crew cab, short bed with 3.73 gears is only rated to tow 12,630#. Even with 4.10's I'd be cautious with the 66rfe towing heavy.
I feel like the 2019+ 6.4 with 8 speed would do okay, but 13,000 dry weight is probably going to be nearing 15,000 loaded out, which will require 4.10 gears.
Moose2
Iowa
Lol! I’d pull a house with 4:10s, even with the gas engine.
Firebird
2019 Ram 2500
You will hate that 6 speed trans. I had the exact truck you describe, and that 6 speed was awful. My 2019 6.4 with 8 speed and 4.10 gears was substantially and measurably a better truck!
Bearcatrp
Step up to a 8 speed if your going gas. Makes a big difference. My 2017 6 speed 3/4 ton sucked going through big hills. Moved up to a 1 ton 2021 Ram long bed. Registration is half the cost of a 3/4 ton. I have a 50 gallon gas tank. Just pulled it up a 6% grade this past weekend. Pulled great. RPM’s stayed around 3000 while my 3/4 ton on the same grade ran over 4000 rpm’s. Am so glade I stayed with the 6.4.
OC455
Central NY
You'd be over max on that truck. My dually has a max towing of 13792lbs. and I have 3.73 gears. The dry weight of that trailer would put me over too.
Moose2
Iowa
So you just like big hips? Yet another good point to get the Cummins powered 3500. Big hips all the way.
jaerbaer1
Colorado
I had a 6.4 with 3:73 gears. Was fine except in the mountains. I wish it had had 4:10 gears.
OC455
Central NY
Yeah, but I have a ridiculous payload...if I had 4.10's I would be closer 17k to 18k towing.
JRs 17 Ram
Missouri
Break your truck? No, probably not. Unless you like pulling that trailer at 25 mph up the hills and watching your gas gauge drop while doing it then you’ll probably hate it. I had a ‘17 and pulled a 2000 lb cargo trailer through Wyoming, with the headwind I got 4-5 mpg. I’d find a diesel, it will pay off in the long run.
Irishthreeper
My ‘21 2500 6.4 w/4.10’s pulls our 5W very well but it’s only 8400 dry. If you’re at 14,000+ lbs you need a 3500 Cummins. Don’t make the mistake of a 2500 Cummins, you’d be over payload with hitch weight alone.
Moose2
Iowa
I 2nd that. Been there done that with the 2500 cummins. Ok for local trips, but upgraded for long distance peace of mind.
David F
San Diego, California
cummins 6.7l diesel
Nope. you gotta go to the one ton. Best with the diesel. I pull a 9980 dry weight trailer with my 2500, would not go more size without going up to 3500.
Dean2
Near Edmonton
All of these towing threads basically devolve into "can you" versus "should you". The formula is bone simple for should, the factors have been repeated dozens of times in the last month alone on a whole wack of threads. Even the guy asking the question knows the answer, or how to calculated it, they are just looking for someone to tell them MOPAR is wrong and go ahead and ignore them. Personally, I stick at least close to the published info for regular use and everyday occurrences, but the odd exception is where the judgement comes in and no on can do that for you. Best of luck.
copcarguy
NE PA
The truck you described will be overloaded.
My ‘21 3500 CCLB 4x4 gas has a 14,320lb. towing capacity with 3.73’s. Had I gotten 4.10’s it would be over 16K.
A good rule of thumb is to get a trailer about 75% of your trucks rating so you have room for passengers, fuel, supplies, and everything else you’ll be bringing along with you.
sam darakjy
wilmington nc
2018 Tradesman Crew Cab 4x4
I have a 2018 2500 Tradesman with 3.73 and my max towing 13093
