Cant connect to OBD port
cblegy
cant connect tp port how to test if the plug is bad?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Welcome good sir. What are you trying to do tune or just read codes??
C
cblegy
i had a check engine light on fixed it went to reset the code and will not connect to the code reader
C
cblegy
cant connect cant get it smoged
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Could be a bent pin in the connector or pushed out pin. I believe it has its own fuse also to protect the computer from an over power.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
^^^^ +1
Double check all that. There shouldn't be any reason it won't work outside of a messed up wire or pin. The reader is a direct connection to the computer.
C
cblegy
no visable bent pin ,fuses are all good
will the plug go bad and how to check
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Normally the port won't go bad. Double check all the connections to the computer to make sure they are tight. Does the scantool fit in snug or is it super loose??
C
cblegy
i have taken the plug off the computer to see if corasion all is fine all is tight fighting scan tool is snug went to 4 diffrent places all the same no connecting
C
cblegy
could something have gotten wet to cause this i have been playing in water
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Possibly but I dont really think so, do you have access to a multi meter? See if the plug itself is recieveing power.
C
cblegy
also just checked there is power to plug
C
cblegy
where and how is the ecm grounded
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Usially it will either use the bolts on the case. But i think I may have seen some use a grounding strap. Just on the off chance is the battery grounded well?? Just a thought.
C
cblegy
also i re ground the ecm i a chance still tthe same
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
It sounds like a blown fuse of some sort. Not sure where or what to. I had read that it was on the radio circuit that communicates with the Scanner. All I can say at this point is to pull all the fuses and check them. I know that sounds redundant and mean but there is a missing connection somewhere. I'm gonna keep looking to see if I can find an answer to this.
C
cblegy
i have changed all fuse and a couple of relay that didnt look right still nothing
C
cblegy
i got thinking i changed my dome light out for a led one could that cause cant connect to obd
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I have heard stranger things happening. Electric gremlins are the hardest to track down. You could throw the old bulb back in and see what it does. I'm assuming the truck is running ok just has the CEL on.
