Can't Figure It Out...
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
I have an aftermarket Pioneer HU. Recently I replaced my 4 channel Sony Amp with a 4 Chanel Pioneer Amp due to my front passenger channel going out. After the install, I noticed two issue that I can't seem to remedy. First, when the HU turns on, a buzzing noise (sounds like interference) is heard but then fades away within 30 seconds. This noise is very quiet, can't really hear it honestly. Second, if I switch over to my radio tuner, a louder buzz noise (again like interference) is heard, but I can drown it out with music. Odd thing is that on any other input (satelite, ipod, etc.) the buzzing goes away. I have tried everything it seems. Gounding RCA's/HU, replace RCA's, etc. nothing makes a difference. This noise does NOT change with engine RPM, so I am not sure if it is a grounding issue. As added insurance to make sure it was the HU, I disconnected it from the amp and plugged my ipod directly into the amp. Clean sound, no problem. The fact that this only happens when on the radio input makes me believe it has something to do with the HU. Is the tuner bad/going bad? Let me know what you think. Thanks! :roflsquared:
baum
savage, mn
2015 Laramie
i would still try to re-ground the amp. was this new amp new or used? if new i would return it.
apepe0738
apepe0738
Peoria, Arizona
This would be a brand new amp. Like I said above I isolated just the amp and the speakers and the sound went away, and only appears when on the radio tuner input, all others are fine. Wouldn't that rule out the amp? Thanks!
Etroze86
Grand Forks ND
Class D amps generally interfere with radio reception. Some have built in chips that kill this effect but not many.
MikeG
Livonia La.
Is your power wire running next to your RCA's ?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
So if you pull the amp totally out of the equation, the noises go away?
Graygoose
Oklahoma
Convert, for now.
small
We've had class d sub and full range amps for some time, no issues here.
Bkhsvt
Chicago IL
If I read this correctly im leaning a little more tward the head unit, If the sound is only happening with the tuner it may be ground related with the installation of the radio or the antenna ground. That is where I would spend my time troubleshooting
Graygoose
Oklahoma
Convert, for now.
small
True mind is still stuck in time when Class D amps originally came out in the mass market.
Yea, new class d full range are very common. Seems like each month technology changes :D
apepe0738
apepe0738
Peoria, Arizona
No if I pull the head unit out of the equation, the noise goes away. I plugged my ipod directly in using the current RCA's that the head unit is using and I get clean sound.
apepe0738
apepe0738
Peoria, Arizona
Correct this is only happening on the radio tuner. If I switch to Sirius, ipod, bluetooth, etc, the sound goes away. The antenna adapter that I am using actually has a wire that connects to the remote wire.
If I disconnect the antenna from the back of the radio, I loose signal, but the noise is still there. What is weird is this just started happening, it has been fine for about a year. You mention the grounding of the radio. What are some things I can try to better ground it?
Bkhsvt
Chicago IL
You can look for metal back there, usually there's a large metal bar going across the dash. I'm betting if you put a new radio in there it will go away. Sounds like an internal radio issue to me
apepe0738
apepe0738
Peoria, Arizona
Thanks for the help everyone, I am leaning towards it being the HU as well...
