Carburetor problems
tlindsey1229
318 5.2L
I have a 1988 d100 with a 318 5.2L v8, the truck was originally a little v6 and the previous owner swapped the original tbi engine with a late 70's model 318 with a carter carburetor. Long story short the rod that runs through the carburetor is worn out and causing a vacuum leak. I've been debating on doing a Hemi swap into the truck or would y'all recommend me doing.
d250
Connecticut
5.2 318 v8/5.9l 12v Cummins
Why not put a 4 barrel edelbrock Carb on it. Or drop a Cummins now that *****.
crazzywolfie
under the truck
i think it would depend on what you are willing to spend. i am pretty sure most hemi swap harness's cost $1000+. that doesn't even include the cost of an engine or pcm. it would be cheaper to get an aftermarket fuel injection system for the old engine than a hemi swap but you would definitely want to make sure the engine is in good shape before putting too much money on aftermarket parts.
Rustycowl69
2001 ram 3500
V10
there used to be a few shops, who would re-bush throttle shafts. Are you sure that is where your vacuum leak is?
Saleen5150
