What gas mileage do y'all get with your first gens?
David Vandercook
Under the truck
Hey everyone, I am wondering what gas mileage y'all are getting with your first gens. I have a regular cab, long bed, 3/4 ton 4x4 318 carter bbd carburetor, no vacuum system. I recently replaced my ignition parts and the carburetor and I went from getting 7-8 mpg to 9-10. Would you say this is normal or bad? Any ideas to increase mileage?
u2slow
BC, Canada
Cummins 6BTA
I got that mileage with my '91 Chevy 350TBI ( manual, no OD) - nearly 8k# truck - with 4.10 and 33" tires. My 1stgens are diesel, and get similar economy to the gf's V6 jeep liberty... sorry if that is only wallet-feel, have not calculated.
I think you have room for improvement. Vacuum advance (distributor) tends to help economy. Axle gearing, tire size, and overdrive are obvious ways to get highway rpm down, but the cost for those can often buy a lot of fuel.
David Vandercook
David Vandercook
Under the truck
Thanks, yeah, my axle is geared super low, but I think I'll keep it that way for the torque. I might look in to vacuum advance though.
Badger 13
North Idaho
2013 Dodge Ram 1500
My 1985 W150 had a 360, 3.55 gears, 31 tires, and it was a thirsty beast. About 9-10 mpg was about the best.
Bob Bash
Maine
1984 W100
I have a 1984 W100 with a 318 and a holley two barrel carb and 4 speed manual . New plugs ,wires,cap and rotor. Standard 15" A/T tires . I can only guess ( my odometer is inop) but 10 mpg is about it .
Dusty
Rochester, New York
I can't think of worse years for bad fuel consumption on Dodge trucks.
Depending whether the vehicle in question has Federal or California emissions package, there may be a black contraption mounted on the side of the air cleaner housing. This is called the OSAC valve (Orifice Spark Advance Control). This valve interrupts vacuum to the Vacuum Advance Diaphragm on the distributor when the engine reaches temperature, slowing down timing advance under throttle.
You can eliminate the OSAC which will improve drivability (and by default reduce fuel consumption) by connecting the vacuum port hose on the carburetor directly to the vacuum advance thereby providing full time vacuum advance action. However, with the engine set at the correct timing this usually provokes pinging at lower RPM. This can be eliminated by replacing the primary spring in the distributor (primary spring has two small loops one at each end) with a heavier one.
Better than that is to recurve the distributor to allow a 10 degree advance basic, to about 34 degrees total if you want to run 87 octane. I would not advise modifying the Cold Air Inlet Door (trap door on the air cleaner housing) if increased gas mileage is your goal.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 129109 miles.
Snowchief
Milwaukee, Wisconsin
I have a 1985 W150 3.21 gears NP435 318 V8 was getting 8mpg and using oil. Got it up to 13-15 mpg by doing a compression and leak down test.Soaked the cylinders after discovering low compression on number 7 cylinder. Compression came back,figure I had a stuck ring.Still was using oil.Replaced valve seals and oil consumption fixed.
shanmccarthy
