Cat Delete?
RAM_it
Hey guys, new here to the forum. I have a question: If I cut out the Catalytic Converter and just put in a pipe instead on my 2002 dodge ram 360, will the check engine light be on all the time, or will it be ok? I have heard that from '03 on, taking out the Cat will illuminate the Check engine light. But what about '02? Thanks in advance.
PCA4208
Albuquerque, New Mexico
Just leave the cat. It makes exhaust not smell and passes emissions for you. Most people thinks it's a real restriction in the exhaust, but it's really not unless you have big horsepower.
R
RAM_it
I would exept that my check engine light is on, and it is a cat converter code. I really would rather avoid spending $800 :nutkick:
PCA4208
Have you tried the 02 sensor anti fouler trick? What you do is remove the sensor after the cat and put a spark plug antifouler packed with steel wool. Onto the sensor, then screw the whole assembly back in. Even if you remove the cat you will need to do this, or get a custom tune to remove the check engine light..
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
So the cat is already removed? What did you do with it? Yes you will get a cel when the cats are removed. Either do non foulers as mentioned. Or turn rear sensors off via custon tune but sensors will no be in readiness mode and will most likely fail emissions.
Sent from my SCH-I605 using Tapatalk 2
R
RAM_it
Thanks I might see if I can get one from an auto wrecker yard or something :/
TheSatinPumpkin
2004 Dodge Ram
5.7L
Go to AutoZone and they can get the actual codes for you. Cant assume the cel directly points to cats.
R
RAM_it
Could you explain a little more? What could it be besides the Cat?
blk00rt
If you do take your cat off, try taking the rear most 02 sensor and putting it in the frame rail, so that it reads fresh air. depending on which cat is bad and how many you have, this trick should work. the last 02 sensor looks for a difference from the front one and as long as it sees a difference for the positive side it thinks the cat is doing its job. I have done this on my dakota for about 8 years now with no cel.
RamSport13
Tacoma, WA
Check engine light can come on for numerous reasons, O2 sensors, MAP sensor, EGR, EVAP system, cylinder misfire, low voltage, you get the idea. Definitely worth going and pulling the code to find out what the vehicle is storing. Whenever your light is on, the vehicle goes into basic mode of running. You will probably see a decrease in performance and mpg as long light is on.
R
RAM_it
Oh yeah but I got the code pulled already and it was a Cat code. Sorry for the misunderstanding
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Some non-dealer shops can not just pull codes but do diagnostics too.
If you do determine the Cat is the problem, there is no point in deleting it.
A better idea would be to check the Rf prefferred vendors for high flow direct applicatin Cat replacements.
WhiteExpress
Midland, TX
I did this on my '00 when my cat brick broke, and plugged the exhaust.
Removed the cat, welded in a piece of pipe and zip tied the rear O2 to the frame.
Only issue I had was in heavy rain / snow it'd throw a code. Made a little shield, never had another issue.
Only difference is the truck was a WHOLE LOT louder w/o the cat.
