RedRAM21
Hello All,
First Posting, but a necessary one for my latest modification, the install of the 8 Position Electronic Switch Panel.
I want to locate the Switch Panel (SP) in the front of the Center Console up against the USB Connector Location. There is a 1" flat area that works perfectly for this purpose and using the mounting hardware supplied with the unit.
Since I don't know the RAM yet, I don't know what is under the area I want to drill into or through. I would like to mount the SP with through bolts, the best method would be to remove the part I want to drill through but I don't know how to do that either.
Anyone familiar with the center console construction in a 2021 RAM BigHorn ?
Any help would be better than none.
Thanks up front for any assist, and any suggestions.
I can get picture but since I am new, I am not sure if I can even post pictures.
