Changed pads and rotors and now this.
Moundman
2009 Dodge Ram 1500
Question for you guys. I just changed my pads and rotors. I then took the truck out to start bedding the breaks and I noticed while I was driving that there was a rubbing/grinding noise coming from the wheels. Couldn't tell if it was front or back or left or right. It would go away when breaking but not while driving. To me it sounds like the pads aren't releasing from the rotors and just dragging on them.
I decided to park it and ask the experts for help. Dies anyone have any suggestions or is this normal? Thanks in advance.
Sent from my SCH-I605 using Tapatalk
WhiteExpress
Midland, TX
My advice, take apart what you did, do it again.
This oddly almost always fixes my issue.
Did you use anti-squeal on the back of the pads?
jlb
MT
CTD
I agree with the above, take it apart. Sounds like you have something wedged, like an extra nut, or a clip you left behind, or....
Brakes are zero clearance, meaning the pad stays in contact with the rotor even when you are not applying the brakes, and with new pads... You should have beautiful silence.
I suppose it could also be your parking brake needing some minor adjustment. How severe is the noise?
012RAMbo
West Monroe, La
You could have slightly bent the dust shield and is making contact with the rotor. Happened to me while installing my lift. Made a horrible grinding sound at low speeds while turning
BlownGP
Houston/Baton Rouge
You check and make sure your brake clips/shims are not rubbing the rotor. They installed correctly?
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
my new pads have always made some noise until they're fully broke in.
Moundman
Moundman
2009 Dodge Ram 1500
Thanks for the suggestions. I went and just kinda looked around and it was the dust cover rubbing the rotors. Just took it for a drive and everything is good. Thanks again.
eterna14
