Chasing a squeak/squeal on 15 1500 4x4 crew
jawxx
Hey all. New to the forum. Traded in my 15 Grand Cherokee for a 15 RAM 1500 a few days ago. 22k on the clock.
So far impressions are mostly good. Its more truck like... makes sense. Rides well. Milking the MPGs and averaging about 17~ so far. I usually averaged 15-17 in the Grand Cherokee so if I can stay close to that I'll be happy.
This thread, however, is about chasing a squeak/squeal. I think its brakes but can't be sure. I have a slight squeal when driving that I can hear when I'm alongside other vehicles or a wall because it bounces back at me. I thought it was brakes because I had some for sure break squeal when applying. Not bad, but annoying nonetheless. The sound sounds like it could also be suspension bouncing around a little... is that a thing in these trucks?
Because I thought it was brakes I knew it would be a battle warranty wise, I went to the store and bought some new pads and swapped out the front. It actually seemed to help a little (but not eliminate) on the stopping but not eliminate the cruising squeak. I didn't do the back because they didn't appear to be worn at all.
So... what next? Should I see if the dealer will drive for a few miles and have a suggestion? Is there other places I should look right now?
Thanks guys.
WiSH2oo0
MN
2017 1500 Express 4wd RCSB
One of my squeaks was on the drivers side, the parking brake cable was rubbing on the parking brake bracket mounted on the rear lower control arm.
Bdersch
i actually have the same issue. a small squeak that i can hear with my windows down. thought for sure it was the brakes because when i slow down i can hear the squeaking. I took my wheels off and checked everything over. Pads have a ton of life left and rotors are good to go. i cleaned everything up really good brake with with and then checked the suspension. I would be curious to hear more about this bad front driver strut. how did you determine that?
jwilkinson79
West Islip, New York 11795
I brought it to the dealer and went for a ride with the tech to make sure he heard what I was hearing. He said it was my front D/S strut, they replaced it, never heard it again. :happy107:
Bdersch
interesting... might need to check mine out then... thanks!!
Dark Knight 500
Alberta
My 2017 started squealing at approximately 17,000km pads look to have lots left [emoji848][emoji848]
LovedMy 2500
