Mack_Sauce_16
I've been hearing some metal on metal chatter in my front right suspension for a few weeks now. I went through the process of testing my joints and bushings with some lithium grease and couldn't find the cuprit so I took it to a firestone. They told me that my brake had been wearing down at an angle and had gotten to the wear indicator at one spot and when I hit a bump it would rub against my rotor causing the chatter. While they had my truck on a lift and the calipers off, I verified that my pads were low and that my rotors looked a bit thin. (I didnt measure the rotor thickness) They recommended I replace all pads and rotors and quoted me at $1,046. No way am I paying that much for brakes and rotors when I can get parts for ~$450-500 and do the labor myself. What I dont get is how my brake pad is rubbing over bumps during normal driving conditions but doesnt make noise when I brake. Also, do you think rotors should be replaced after only 60,000 miles? I'm going to make an actual measurement later this week but I'm curious what you guys think.
2008 Ram 1500 - 5.7 - HBS 2" level
