tommyboi87
- May 28, 2014
- 861
- 224
- Location
- houma louisiana
- 1999
- 5.2 Magnum
This is on the passenger side of the intake manifold. is the piece connected to the 90 that is coming off the manifold a check valve? If so, should air travel freely through both sides? If not which way is the air supposed to flow? I'm thinking it is a check valve, and the air should be flowing through it from the intake manifold, and shouldn't be allowing air to go back into the manifold. Which is what I think is causing my a/c problem seeing that the vacuum line coming off of it goes to a little splitter that goes into the firewall. Just needing some insight before I change it so I don't mess something up. So by all means, correct me if I'm wrong. Thanks guys.
Sent from my SAMSUNG-SM-G925A using Tapatalk
