gto64gto
I have a 2017 Ram hemi 4 wheel drive crew cab. When I back up and have the steering wheel turned to the right, there is a clicking noise that sounds like its coming from the left front. I've had it in once to have it checked at the dealer. They replaced the cv axle but that didn't stop it. It only does it when I"m backing up and the steering wheel is turned to the right. It doesn't do it backing up with the steering wheel turned to the left and it doesn't do it going forward. I took it back to the dealer and he's had it a couple of weeks. They gave me a loaner to drive while they fixed it. I called the service manager today and they still can't find the problem. He said they were going to Velcro sensors to various places on the chassis to isolate the sound so they could find what the clicking is. You can hear it on the outside as well as inside. He said the only thing they found was LISTER TO THIS was that the top and lower ball joint nuts were loose and were torqued to the correct specs! I have never heard of such a thing. All I have ever seen with these nuts were slotted castle nuts with a cotter key. They still have my truck and one of the first things I'm going to check is if the ball joints do or do not have slotted castle nuts. Has any one out there experienced a clicking noise when backing up with the wheel turned to the right? If so, what was the problem and the fix? Thanks so much for your time. I hope some one can help me.
