Clunk from P to R, is it normal? Mine is a 2023 3500 RAM diesel 6.7
jorodriguezji
Hi everyone!! I just have couple of week with my new 3500 RAM 6.7 Diesel and a lot of time the shifting from P to R is a very laud “clunk”. Is that normal? Highly appreciate yours inputs. Best!!
jws123
nj
Could be many things maybe it needs to break in a bit? your truck is still under warranty I would have dealership look at it.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I know when I had my HO equipped truck with the aisin trans, that thing would clunk so bad when shifted no matter what. And man, if you changed gears without coming to a complete stop, if would jerk your teeth loose. Now with the 68RFE trans, no clunk.
tjfdesmo
AZ
The Aisin does this, for sure. I learned to pause momentarily in neutral, and you will hear it "unload", then it will not bang when changing direction or going into park. Just another quirk of the Aisin.
RamDiver
Marlborough, Ontario Canada
2021 DS
If I switch the transmission too quickly from reverse to drive without fully stopping and a short pause, my Warlock will occasionally clunk a little. :cool:
I always stop before shifting but the pause time seems important to avoid the slight clunk noise.
Choupique
Louisiana
Cummins
The aisin transmissions are notiously clunky and noisy and jerky relative to other light duty truck transmissions. Obviously a loud bang is not normal, but a little clunk wouldn't concern me. It's a meaty transmission meant for heavy work.
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Make sure you are not parked on any kind of a incline. Also before you take your foot off the brake engage the parking brake. That will help reduce the strain/pressure on the transmission in park.
