Clutch fan delete question
Lil Ram
south texas
I have a question for y'all...what are the benefits of deleting the clutch fan? Is there a lil of power to be gained?
Thanks for any info
shortman
*******, GA
The only thing I can say for certain is the truck doesn't have that stupid fan roar when you first start it. It was worth the removal just for that!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
My 2015 with the clutch fan screams on startup. Removing the clutch fan is usually worth about 8-12hp. Not a huge improvement but not bad either considering how cheap of an upgrade it is.
Lil Ram
Lil Ram
south texas
Will the stock electric fan and 180 tstat be enough to keep cool?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The stock one should be OK, but on the 09-12, I prefer to replace the stock AC fan with the V6 model fan. You can buy this real cheap if you go with the TYC #622320 fan.
Lil Ram
Lil Ram
south texas
Ok thanks I will run it like that for a bit till I get the v6 Efan
brusk
Tennessee
I ran my stock AC fan without the shroud for a week while I waited on a non broken V6 fan to come in. It did the job but the temps seem to fluctuate quite a bit in traffic and I had easily a 5-8 degree variance. The V6 fan is consistent and runs as much as 4 degrees cooler than the other did. In my case having a shroud might have helped with the original, people tend to forget the importance of a shroud.
Paluby
Alaska
Yeah I'm having that happen right now. I don't have the bottom portion of my shroud on and my temps are all over the place.
