Clutch for 2018 3500 6.7L
JohnMac
Ca
Eco Diesel
I own a 2018 3500 6.7L with a 6 speed manual trans. The clutch will slip if I accelerate hard in a higher gear (5th or 6th). The only heavier clutch's I have found eliminate the factory flywheel and replace it with a solid flywheel. Does anyone know of a clutch with maybe 20 or 25% more holding capacity that uses the factory flywheel. Thanks for any and all help.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
Check in with the guys at either https://www.cumminsforum.com/forums/ or https://www.turbodieselregister.com/forums/
ChloeBrooks
