RAM8610
i currently have the nv4500 pulled out of 5.9l magnum (02 ram 3500). i have a few questions hopefully someone can clarify a few things for me. i have attached photos as well.
1. my pilot bearing was shot and i have a little wear on my input shaft, huge issue? or ok to procced on reinstalling a new clutch kit.?
2. fly wheel and pressure plate both have those heat marks what caused this heat friction? poor clutch driving?
-i would like to add that this truck is a chassis cab with a stake dump body and we've overloaded the GVW many of times.
3. currently has the 11" clutch, will the 12" clutch and pressure plate really fit.? and will that effect choosing a new flywheel as well or any other component that will not be replaced.
4. the pilot bearing was definitely shot as you can see in the pictures. was that little bearing causing me not to shift into any gear or was it the clutch release bearing that has all the oil and play in it?
5. help me understand how this clutch works. what i do know is the ***** cylinder pushes on the shift fork which has a clutch release bearing". as that pushes out what is actually happening after that between pressure plate clucth and flywheel. never understood or seen how that works. also in reverse you release clucth pedal, ***** cylinder rod retracts and shift fork returns???
