Code PO355
Floorboard
DE
Having a problem with my 2003 Dodge Ram Hemi 5.7. Has a code PO355 and don't know what it could be. I've changed the number 5 coilpac and still have code, anyone had to deal with this?
HarryS
Air Force
Clovis NM
First, when you suspect a bad coil, don't replace it, swap it with a known good one, and see if the issue moves. Then pull the plugs and check plugs and do a compression test.
jws123
nj
Have you overheated it recently or anything
Reticle918
